- Aug 7, 2021
- 33
- Vinyl
- Hayward Aqua Rite (T-15)
I’ve been working on a leak for about a week. It seems slow. About 2 inches a day. It just went lower than the skimmer so im Guessing the light niche. It was replaced about a year or so ago. Perhaps the epoxy gave way a bit?
I noticed that the new light doesn’t fit perfectly so there may be more movement then normal. I tried to use some food coloring but I didn’t notice any suction. I assume it could be a small leak.
I also can’t figure out where the water is going. No wet/sunken areas.
I plan to add more epoxy in a bit and mark the level again. I’ve had the pump off this whole time so I’ll need to SLAM once it’s said and done. I’ll also have to find a better way to seal the light housing. Is there an adapter or something for this type of thing?
If it’s not the light. I’ll be at a loss.
Advice appreciated. Thanks in advance.
