Hey folks, my pool has been losing water every day so naturally I suspect a leak but there are some odd symptoms I’m hoping you can help explain.
Every day I lose maybe an inch, bucket test confirms not evaporation. The water drops to almost the bottom of the skimmer entry (but not quite) so I naturally suspect either a crack in the skimmer near the mouth or structural crack in the concrete. Spent an hour with some dye, no movement in the skimmer whatsoever.
Then it dawns on me, since I moved into this house a year ago and fixed up the pool there has always been 1 return jet, furthest from equipment, that has no flow, all other jets are fine (5 total).
I then do a bucket test again, 24 hours with pump on, then again with pump off. No water loss when system off is it appears to be pressure side. The odd thing is, when my pump turns on and primes, I get bubbles out of this jet (all my jets have some bubbles during prime, then normal flow). This jet just shoots bubbles during prime, then no flow at all. Since my water drops only down to a certain point I feel like the leak is probably near the return itself (it drops to maybe a few inches above the return.
Any further tests I can do? Should I do a dye test on that return while the pump is on so see if the fitting is leaking? Why would bubbles come out but then no flow, maybe there’s also some blockage?
