We have a new gunite build, pool/attached spa. A bucket test verified that we have a leak, and a dye test revealed the leak is in the spa at one of the inlet jets (about 300 gallons per day). Looks like the leak is at the joint between the plaster and the plastic flange/socket of the inlet. We "red neck" fixed it with underwater duct tape (see photo) that is surprisingly is working.... and we're back to our normal "evaporation" loss, which is about 3/16". The tape fix, I assumed, eliminated the possibility of any cracks in the actual plastic. The spa inlets are different from out pool inlets that they are these translucent recessed two-piece inserts that thread into the plastic housing/socket. they have two little protruding tabs on top, presumably for a "tool" that we don't have. The tabs are about 1/4" x 1/8" high and about 1-5/8" apart center-to-center, clocked 180-degrees from each other. I can easily drain the spa water into the pool in a few minutes to get complete, dry access.
What is the preferred permanent fix for a hairline crack/gap like this? I am envisioning anything from an epoxy to a silicone to a plaster slurry to a plaster removal & repacking. Assuming it's a silicone or epoxy, what is the preferred product I should buy? I'd like something with low viscosity that can inject into the hairline crack/gap-- preferably in a small syringe that's injectable. And what is the "tool" I need to remove these rings from the spa? I could only remove one of them by hand.
