- Jul 26, 2022
- 243
- Plaster
- Pentair Intellichlor IC-60
Haha yea certainly unsettling. What pump is recommended for my set up?Smoke and electricity -- best to replace the whole thing.
Here’s a vid on my iCloud. Too big to upload.Video?
I’d prefer to fix this issue if possible…but If I end up having to replace it, then I’d like to spring for something that will have enhanced features (such as variable speed) and durability. I have a 2hp now…should I go to 3hp? Any specific models that are recommended?A basic Intelliflo can be controlled by the Aqualink automation I believe.
Nope. No water flowing through. Assume bc the pump isn’t getting water flow/primed.What happens if you open the red handle valve?
Does water go out the waste line?
Here is a vid with the lid off. iCloudCan you turn on the pump with the lid off and show what the water in the pump does?
Perfect thank you!As I said, Intelliflo. That is a VS pump. The Aqualink can only control rpm not flow, which is OK. The 011028.
The link is to the EC model. 1 year warranty with DIY install.
Will do that now. Give me a few
You can remove the actuator and then open the valve to see if anything is clogged in the valve.How would I check it?
Opened the lid and can’t feel any blockages on the inlet side. And I could rotate the impeller freely on the other side. Will check the valve nowYou can remove the actuator and then open the valve to see if anything is clogged in the valve.
Maybe check the impeller for debris.
Feel into the pump inlet near the union to see if anything is clogged at the pump inlet.
