- Aug 27, 2022
- 26
- Plaster
- Jandy Aquapure 1400
Hey everyone, unfortunately I have a leak after losing power the morning of Christmas Eve for 4 hours. Fortunately, the pool stops leaking about a 1/2” under the tile, prior to that is ~1” in 24 hours, 20,000 gal pool. I wanted to get opinions on my plan of attack. The only place where the plumbing would be at the level where the water is, after it stops leaking, is where it ramps up towards the pool equipment. I was going to use a string and a level to find this spot and start digging to see if that is where the leak is. I’m assuming it is somewhere in the plumbing. This is this pool’s first winter, equipment was running fine until I lost power and had to do an emergency drain, after about 2 hours of no power, water temp before power outage was high 30’s, air temp was 9. Thanks in advance and my skin is thick, so don’t hold back!
