Laars Lite 2 LJ problem
Finn59
2
Boston, MA
I have a 12 year old Laars Lite 2 LJ nat. gas model that is not working. I am able to toggle from OFF to POOL, but the circle (which I believe indicates water pumping thru) is not rotating, no temperature reading - basically nothing happens. No codes appear as well. Does anyone know what this issue might be? I am thinking due to the age of the unit, I may just replace it. Any thoughts or advice is appreciated.
If it is not indicating flow, check that the filter is clean and pump basket not clogged. Then, check pressure switch.
