Kleen Strip Green…. What strength in Pool Math?
JamesR
339
Nazareth/PA
CircuPool RJ-60 Plus
Lowes does not have anymore of the blue label Kleen Strip muriatic acid. I had to get the green label. It’s not clear at all on the label or the MSDS what the concentration is.
What are you folks logging it as in PoolMath?
This stuff..
Look on the side or rear panel for a percentage.
If there is none, I'd estimate it is probably 14% as it says 'Lower Fumes'.
It will likely have a lower concentration, but the SDS is not really helping:
Maybe someone else chimes in later who has used the product. Otherwise I'd dose as if it was full strength MA, then check pH after 30 min and add more. If you consistently have to add double the amount to get the effect on pH you'd be expecting from full strength, then you can probably assume that it's half strength.
