Hello Experts,
Hope all of you are doing great!
I know this question has been asked before multiple times, I swear I tried reading all of them and did not feel it addressed my concern. Hence posting.
I have a JXI400P, Bought it used from a private seller who needed NG rather than Propane. The heater seems to have been manufactured in 2020. The heater worked fine, until I was away for work, came back home and it had killed the breaker.
What did I check and What have I done till yet:
1. Opened the heater up and tried to troubleshoot what was tripping the breaker
2. Turned out it was the transformer, even when not connected to the board would trip
3. Replaced the transformer with this Amazon.com . Bad idea?
4. Heater turned back on. Blower turns on, I smell gas, tries to ignite but does not
5. Cycles through that 3 times and then gives me the check ignition steps error
6. I checked if any wires were loose and then also checked the ignition rod, looks braaand new!
7. Put everything back, same problem, smell gas but no ignition.
Need your help. Cant really call warranty and I live in a small town so closest repair guys is weeeeeeeeeeks out.
Thanks in advance.
Fahad
Thanks in advance.
Fahad
