Hey guys,
This is going to be a little bit of a brain dump so I hope you don't mind.
I have a 12k pool with a SWG TurboCell T-Cell 15. Since we purchased the home, I always had maintenance people come and do everything. I didn't know a lick about anything and we just got in the pool. About two months ago, our pump died. We went from a single speed to the intelliflo VSP. Literally within the week of installation we ran into more issues and so we decided to re-plaster the pool (and put in a new skimmer). At that point, I decided I was going to fire all maintenance people and take over myself. The plaster was completed and over the next 5-6 weeks I've been on this board learning as much as I can (including getting a proper test kit!).
Since we have a SWG, today I finally dumped in salt. According to the system, we have about 800ppm of salinity. My drop test showed 1,200ppm. So I put in 5 bags of salt to see where i'm at tomorrow and if needed I can drop in bag 6.
My first question is regarding the pump & swg. Our old pump was connected to our Aqualogic PS-8 and ran from somewhere between 1pm-8pm. I believe this is when the SWG would kick on and chlorinate the pool, correct? The new VSP is not connected to the Aqualogic since it is my understanding that they cannot communicate with each other. I operate the VSP manually.
My main question and what I assume is the case, is that the "pump" light on the Aqualogic still needs to run in order for the SWG to kick on. If that is indeed the case, then I need to program the Aqualogic pump times to match that of the VSP pump, correct?
Currently the VSP is running 24/7 at:
Speed 1) 8am-12PM @ 3000 RPM
Speed 2) 12PM - 8PM & 2400 RPM
Speed 3) 8PM - 8AM & 850 RPM
After reading around here over the last weeks I'm considering lowering the 1& 2 RPMs and upping the #3 RPMs.
Additionally, after reading the Aqualogic/SWG manual, it seems that my SWG is meant for double the size of my pool (not sure why the previous owner chose that). The SWG has always been set at 75%. After reading the manual 75% seems like a lot. Should I put it to 50% to match the size of my pool?
I might be forgetting something but that's it for now. I appreciate your time and any help! Thanks!
