I opened my pool on Tuesday. I live in the Northeast so it's pretty chilly still but I wanted the pool to be ready in a few weeks. Anyway the chlorine level is not being maintained after shocking. I've been using liquid chlorine daily in the past. I shocked with cal hypo and because I'll be away I'm using trichlor in a chlorine feeder just for this week.
Anyway the PH is fine at 7.4 last tested. When I used the Taylor DPD test nothing registered. At first I thought it bleached out because of too much chlorine but after testing with an OTO kit there is NO chlorine.
I tested the CYA and there is 0. I thought the trichlor would build up the CYA but it's not happening. Questions-
The trichlor is a year old. It smells pretty pungent still. Each tablet is individually wrapped. Can it be bad after only a year?
Should I add stabilizer or shock again with stabilized shock (dichlor) to raise the CYA?
The water temperature is about 59 degrees. Not sure this matters but thought I'd mention it.
Once I get this straightened it's back to liquid chlorine.
Thanks in advance.
Bob
Thanks in advance.
Bob
