Glad to hear you have the solar cover and don't get much debris. That will make things much easier to manage. I would say the jury is still out on whether or not to use the solar cover with the forecast calling for 3 days of rain. If you get a lot of rain, your pool can get too full and the the pump and filter will not be able to work properly until you drain some of the water out. Also, rain water can affect your pH in different ways. Sometimes it will lower the pH because it is acidic. Other times it may raise the pH because of the aeration it causes. The extra water will also dilute your chemical levels, which is what we don't want, unless your CYA is too high.
The more I think about it, the more I am opting with putting the cover on while you are away. Anyone else want to chime in? I'm not sure how the cover will act with the rainfall since I don't use one on a regular basis.
