The answer is that it varies. It mostly has to do with the TA level in your pool, the TA level in your fill water, and how often you refill the pool. High TA means lots of acid use. But so long as your fill water TA level is low, or you don't refill much, then you will be lowering TA one time and then stop. On the other hand, high TA fill water and lots of topping off could mean a great deal of acid usage.
By the by, muriatic acid is inexpensive enough that I doubt you could possibly be using muriatic acid, as even a great deal of acid would only be $10 or $12.
