I’ve had an algae issue for quite some time now. I’ve never had green water but algae will form on the bottom of the pool. It is not growing on the bottom but I believe it is growing in the water and eventually settles on the bottom. If you stir up the water, say by waving a skimmer net just above the bottom, the algae will also stir up with the water (i.e. it is not stuck to the bottom). It will also grow on certain sides of the pool if I don’t brush it 2-3 times/week.
I did a SLAM this summer which took about a week and I performed it by the book and ended when there was no sign of the algae, CC was 0 and OCLT was 0. In about 3-4 weeks the algae was back again.
I assumed I somehow did not keep the SLAM going long enough so I performed a 2 week SLAM which I kept up for about a week past where the 3 tests indicated I was good to stop. I also kept the FC levels elevated for several weeks after the SLAM – nominal FC is 5-7 (CYA 40) and I have kept the FC between 9-11 post-SLAM. The algae returned again about 3 weeks after I ended the SLAM even though the FC never went below 9.
The caveat is that my phosphates were above 4000 ppb. I know, I know, I know, the consensus is that they don’t matter but I am getting very tired and frustrated by this. I do not have the Taylor phosphate test kit and the pool store test maxes out at 4000 so I didn’t know how much above 4000 they were. I know the opinions about pool store testing but I took a sample to another store and got the same results. I also have just ordered the Taylor K-1106 kit.
After this last SLAM I treated with Orenda PR-10000. The water got cloudy but not very cloudy and I got the white junk on the bottom. After that the pool store tested the phosphates at around 3600 ppb. There’s obviously something wrong here but I can’t come up with anything other than the high phosphates are feeding the algae even though all the talk I’ve seen on this site say maintain the FC level and the phosphates don't matter.
