Hulligan, the increasing clarity signals to me you're on track, so kudos!
The slower "color" change may be due to iron in the water that has oxidized from the slamming (an effect of chlorine if you have metals in the water that we discussed earlier.) I suspect that sand filter of yours will just keep chugging away clearing it over the next few days.
If you get to the place where you pass all the slam criteria (less than .5 cc, less than 1ppm loss FC overnight, water clear) and youve vacuumed entirely clean, but still have the yellowish tint to the water, THEN I would let the FC drop, get ph to 7.6, and treat with Metal Magic.
If you want an iron home test kit, this is what I use, but if you meet the above criteria and the water still has the yellow cast you don't really need to test to treat http://www.amazon.com/LaMotte-2994-...8&qid=1431430588&sr=1-2&keywords=Lamotte+iron
For stains, while AA is sure fire, I found from advice from a TFPer named Ravenjim that doing the Metal Magic sponge test and treating accordingly removed my stains just as well.
With AA treatment (ascorbic acid) you have to add metal sequestrant anyway. The advantage for me of only using the Metal Magic in larger dose was that you were killing two birds with one stone, and it was nowhere near as difficult to increase the FC after (and it works at a higher FC than AA).
Here's a link to the sponge test for future use: http://www.proteampoolcare.com/images/uploads/MetalMagicSpongeTest.pdf
And here's the link to Ravenjim's excellent step-by-step thread on the topic: http://www.troublefreepool.com/thre...estrate-from-EDTA-to-HEDP?p=658877#post658877
Cheers!
Thanks Swampwoman! I guess the plan for now is to wait until the algae stops clumping on the bottom? The water is getting so clear but is still discolored. Then, take care of any metals that are in the water. We are on well water, but most of the water in the pool has been in there for years and I am guessing rainwater? We have added several inches from the hose to replace loss from backwashing but most is still the "original" water.
Thanks for the good reads...I'll do the sponge test once the slam is done.
