Hi folks,
I’ve got a Jandy controlled pool with a Jandy spa jet pump and a pentair vsf filter pump. I run the filter pump on a 7am to 7pm schedule. For the past few months I often find the filter pump is off even though it should be running. The Jandy system correctly reports the filter pump status as off. On one occasion inhad the spa jet pump running and that also shut off unexpectedly in a similar fashion. I only have one program running on my schedule; I’ve confirmed that the “maintain pool temp” feature is not enabled, my anll off time is 11pm and I’ve confined that the Jandy clock is correct.
As a test I’ve disconnected my spa side controller which has no affect on the issue.
Any hints or suggestions of what else to look for would be appreciated. I’m confounded by this symptom.
Thanks in advance.
Peter
Thanks in advance.
Peter
