I am a building automation guy with a fairly decent HVAC background, but this one on my own pool has me stymied. Up to this point, I have replaced the ignition controller and the gas valve. I see several attempts to ignite and then it just locks out.
I see the hot surface igniter heat up, I hear the ignition controller attempt to energize the gas valve. I see my meter fluctuate for half a second, but never really registers 24VAC to the valve. When I disconnect the common/ground directly on the gas valve, I have 24VAC through the coil of the gas valve for about 5 seconds. I'm guessing the flame failure is working as it should in this case and cycles the ignition, since the valve is essentially not wired.
I have a 100VA 24VAC transformer that I wired directly to the gas valve and confirmed that it opens. I tried using this same transformer to power the entire low voltage side of the boiler (disconnected factory transformer), but did not help.
I tried jumping the common/ground of the valve straight to ground also. Just makes no sense to me. Guessing I need to check that the heat call is constant to ignition controller. Not really sure how the gas valve input on the universal control power interface works.
Any ideas?
Any ideas?
