Hi! I saw this thread with what I think is a similar issue, but wanted to see if anyone has any other thoughts.
I've got an LRZ (2013), and recently it had a Check IGN Control Fault appear, so I had my regular pool guy come out to try and resolve. He changed the IGN board I believe and the fuse, and checked the volts. It worked for a bit, he left. Over the weekend, it came back up, so he came back out with another fuse. Changed it so now both fuses were changed, voltage there, left. It happened again while I had it on after he left. I noticed that it basically went wrong when it got up to 88 degrees (supposedly) in my Screenlogic app, which was about it being on for 10 minutes.
The pool guy noticed that my PG&E gas meter isn't sending enough gas to the heater (250), as the heater itself is intended for 400K BTU . He pointed it out because he thinks that soot has built up due to this, which would require an intensive and costly cleaning. His advice here is to just buy a new heater.
Is that really my only solution? Does anyone else have any other suggestions? So far, this has been a costly attempted repair, which of course puts me in the could-woulda-shoulda mindset of maybe I should've just replaced instead...but hoping there's still some good news here on what I can do!
I will reach out to PGE about changing the meter to allow more gas, but I'm really even thinking about whether or not I can invest in an electric pool heater (I think my pool is 30K gallons), but he said that no such electric heater exists (haven't done the research really, just was an idea since we have solar).
Thanks in advance (and sorry if I got some of the terms/lingo wrong here!!)!!
