Been 10 years since my last question so I'm way overdue.
Unit: Jandy LAARS LT Pool Heater
History: Past few years I've replaced a Pressure Switch and a Run Capacitor. In 2017 I replaced the 150 deg Hi Limit Switch. Not sure why I didn't also replace the 135 deg at that same time. Stupid.
New Symptom: Turning on the Spa mode, all seems to start up fine with the pool to spa dual valves turning fine into position. After the fan runs high speed to clear out the air in the heater, I hear the gas line valve click on, the burner fires up, the fan is on a lower speed and HOT air coming out of the (clean) vent. A few seconds later when fan switches to high speed, the burner suddenly shuts down. It then recycles all over again trying to fire up successfully. Never does.
What I'm thinking: I don't want to be shot gunning parts that are not the issue. Could it be the other Hi-Limit switch (135 deg) that was never replaced OR be the Temperature Sensor? Or some other part?
Thanks for any suggestions others may have!!
