- Apr 23, 2021
- 16
- Plaster
- Jandy Truclear / Ei
Hello,
I’m having new trouble with a 2 year old new install. Pump is variable Jandy 1.65hp with 2” pipes I believe.
I used to be able to run the heater on pool or spa 3450rpm without issues. I’ve found the only way the heater will work is lower rpm like 2400.
History: Pool is 2 years old, one pool store told me to drain it for CY at 110(dam test strips lead me astray), and water hardness 900.
Leslie’s said let it ride, add nophos for high phosphates 900. I did, cleaned the filters, phosphates down to zero life was good.
A week later I had the tiles bead blasted which involved lowering the water level down 6” below the tile line. They had a big pump so I asked them after they vacuumed all the debris to drain it 75%. I finished the drain to empty over the next 2 days as the sealer set for 48 hours.
Refilled pool with the pvc fill(not auto) and another garden hose. Put brand new filters in. Leslie’s said phosphates were 1787 so I added 110 oz of no phos and ran it 48 hours straight and then cleaned the new filters.
Last sample was good, go easy on me I’m done with pool stores and I’m a believer in DIY, just awaiting my test kit and won’t be using anyone else but myself, pool math, and this forum.
Pools been looking great. I went to use the hot tub and discovered the heater never kicked on. I have automation so I disabled that from the equation. The last fault recorded said check gas valve. After clearing that (before I ever got it running today), never saw it again and only get check flow now.
Messing around with pump settings the heater kicked on at 2400 rpm. Anything high I get a check flow fault no matter if it’s set on spa, pool, or pool with waterfalls. For reference all these used to function without issue.
I heard the Versaflow valve opening and closing and can hear the water going in and out of the heater.
At 2400rpm set to pool/waterfall it comes out of the waterfall but about 70% less. Not trickling, not gushing, but enough to clear the raised wall versus running down the wall.
What are your thoughts? Attached are the pressures with the heater on or off with no change from the 3450 rpm. Essentially 8psi off, 12psi heater on.
I appreciate your time and any suggestions!
Pat
Pat
