Ever since I installed a two speed motor last year my Aquapure hasn't run consistently since. If I set the PDA to start low speed in the morning the motor starts on high for a while then switches to low as it should and the Aquapure service light comes on. If I set the high speed to run for about about ten minutes before engaging the low speed the Aquapure works fine all day. I would just use the two programs and leave everything as is but I also have a spill over spa and whenever anyone uses the spa and switches back to pool mode the service light comes on. If someone uses the SPA in the morning then the Aquapure won't work all day until the next cycle starts in the morning.
Is there a special way to calibrate the the new style three port sensor with the small board when you have a two speed pump ?
I have the older set-up with the Aquapure board hidden behind the Aqualink board.
I have the new three port sensor with the calibration board.
Aqualink PDA4 - Board has 2006 date and chip says Rev 1.2
Aqualink Board says Rev C
