Hi Team: I have the aquapure rs with low voltage electric heat pump. The heat pump works fine manually. When I switch the heat on with the app or manually, I hear the relay move and the control board 'heater' light turns on/off as expected. However, the heater does not turn on. With voltmeter, I found that there is no power coming out of terminals #1 or #2 (low voltage heater) on the green 10-pin terminal bar. Appox 24+v comes out of the vacant 'electric heater' plug at the bottom of the control board. Switch 1 dip switches 1 & 2 are on, also Switch 2 heat priority is on. Remote on heat pump was tested by Jandy pro.
Is there a fuse that controls power to the the green 10-pin terminal bar? Something else i can check and fix relative to the terminal bar? Can I use the vacant 'electric heater' plug to connect the heat pump?
Thx in advance.
Thx in advance.
