I have a 35,000gal Salt Water Pool inground with plaster surface that was built in 1983. It was a chlorine pool until about 10 years ago when it was converted to salt water. I replaced the cell at the end of last season.
No service codes. According to the control center everything is working fine, but the first problem is the up chlorine production button(arrow) stopped working. It makes no sound when pressed. All other buttons/lights work. The switch on the circuit board under the button looks fine and clicks when pressed. I can turn chlorine production on by using boost function, and light says cell is on but no chlorine is being generated. No obvious burns/breakages on circuit boards.
While I was troubleshooting the backboard code 170 appeared for 10 minutes then disappeared.
I did the assessment on the backboard, transformer, and front board with my multimeter.
The only readings that were out of line were 4-5 120mVAC was 0 and the Cell Voltage Output to the cell was non existent also.
Transformer voltage reading (1-8) was 81V, (2-7) was 72V, (3-6) 21V, and (4-5) was 0.
I was not able to test front board because i needed help to hold everything. I will as soon as I get an extra set of hands.
I would prefer not to have to replace everything in the unit and wanted to know if anyone had a similar problem and what the solution was for them.
How do you know if the backboard is bad versus the transformer or front board?
Thank You,
Northshore
Thank You,
Northshore
