Issues with pool coping
brianlhughes
5
Calfornia
Hello all,
Looking for some advice here. Pool coping looked ok until we hosed it down after it got dirty 3 weeks after it was installed. When getting wet it looked like it was scaly or micro cracks until water eventually soaked inn then it was a solid color. Then after we had some rain the coping looks wet a week after. It seems dry just appears wet. We are not happy and trying to negotiate with pool builder on how to resolve it. I believe it needs to be ripped out and replaced. Has anyone see this before and know what happening here? Also what are your opinions on how to fix it.
Thank you for the Help!
Welcome to TFP.
I think what you see is the nature of the material you chose.
Maybe @AQUA~HOLICS has dealt with that material.
What you described is normal for poured concrete.
Reactions: .ben
New Pool Coping Came out great! So the difference is we had them bring concrete in on a truck instead of hand mixing, did a plastic barrier between shotcrete/coping per pool engineering, and we did an acid wash finish on concrete instead of broom. We now have no issues at all. When it gets wet its all the same color and it drys fast without staining. We are very happy! I hope this helps in case someone else has the issue we did. Don't settle for it! Make the replace it and do it right!
Sounds to me like the inconsistency of the hand mixed batches of concrete were at the root of your problems versus a single consistent truck mix.
That is an important difference in the quality of “poured concrete”.
