That is one reason that I really like the SpeedStir, removes the hand swirling required to do an accurate test with lots of drops. It looks like you are almost there, shouldn't be much longer.
He is in Florida and still using the pool, so I do still suggest raising the CYA after dumping some water to fix the high salt content. The CYA is going to be lower once the water is replaced and it is already low for a SWG pool.I would normally agree with bumping up the Cya, but this time of year, I don't think there is a huge rush. Not that it's bad advice, there just isn't as much intense sunlight this time of year. I think Ping gives a good place to start, so go from there. You still have enough FC for at least a few days anyhow.
I didn't say not do it, and I also said you weren't wrong...I just said that there was no rush!! And there isn't, he will be fine either way he goes. My main reason for saying so is his FC level. He has plenty to carry him for a few days.He is in Florida and still using the pool, so I do still suggest raising the CYA after dumping some water to fix the high salt content. The CYA is going to be lower once the water is replaced and it is already low for a SWG pool.
