I noticed that with the FC at 22, it fell to 15.5 during the day. My shock target is 15 (pool calculator) or 16 (cya chart). So, yesterday I tried to crank it up to 23 to make sure it wouldn't fall below shock level any more. Measured it an hour or two later (7pm?) and it was 24. Guess I didn't measure the bleach right. This morning it was 23, so I may be getting close. I left it at 23. It was dark, so I couldn't see much, but I think it's still cloudy. Weather turned chilly (that means 50's in Texas) overnight and there was smoke coming off of the water. I suppose that's OK, not anything wrong.
I have a bag of diatomaceous earth that I got from the feed store. We used it to control fleas. Would adding some to the sand filter help it to clear the water better? I can always back-flush it out later, can't I?
Still have the pump running 24/7 and I brush daily. I can never tell by the pressure gauge when it needs a backflush. It's always just sitting there on about 10 PSI. I feel the water stream and if it's weak, I backflush. I have a 2" inlet but the outlet is the stock little sprayer that came with the pool. I wonder if that's restricting my flow too much? When I backflush, a TON of water comes out. With no back pressure on the waste port, it makes a lake out of the side lawn.
-Mark
