I have a 16,000-galloon in-ground pool, and during the summer months here in Los Angeles, I find that I need to add 48 ounces of chlorine daily in order to maintain around 4 ppm of free chlorine/total chlorine. (Which translates to over two gallons of 10% sodium hypochlorite every week.) My other levels are: pH 7.8, TA 98, CH 267, CYA 30 (I'd like to raise CYA a bit, to maybe 40). At its daily peak, water temp hits 85 degrees. Really the only other chemical I add, once a week, is muriatic acid, to knock down my pH, which has a tendency to creep up to 8.1/8.2 over the course of a week. The water's crystal clear, I'm having zero problems, I'm just curious if this level of daily chlorine consumption is normal for this time of year, in this part of the country? Thank you!
