You only need to test CYA if you replace a lot of water. The CYA test is very sensitive to lighting conditions. It is best to do this test outside in bright sunshine, with your back to the sun and holding the vial at waist level. You can pour the solution back and forth from the mixing bottle to the test vial to confirm your results.
