- Aug 27, 2012
- 29
Greetings all,
I have a StaRite SR400NA heater, and need to replace the pressure switch. The one I have now is a TecMark switch and its model info says "4037P- CWCW, K30F/3005" (see first photo). One I found to replace it has similar, but non-identical model info: "4037P , K30F 1814" (see second photo.
Will this replacement work, since they are both 4037P, or should I be suspicious because the model info is not a perfect match?
Also, I have never installed a pressure switch before, and I see there is a dial. Am I supposed to set it to shut off at a particular pressure? Seems like that might be a little tricky; is it?
Thanks!
Otherchuck
Thanks!
Otherchuck
