You can make some tweaks here and there but that is a loud pump. Enclosing it in an insulated box is the best bet but you will not want to do that in the summer....too much heat.
I would try increasing the back pressure. If there's any valves on the return side, try closing them slightly. If there are no valves, try return fittings that are slightly more restrictive than the ones that are there.
The only valve on the output side is a two way between the in-floor and the spa jets, moving it to either or somewhere in between makes no perceivable difference on the volume or tone of the noise. Trying to use more restrictive return fittings may work a bit, but with the water being 45*, and fresh plaster so I can't run the heater i'm not really in the mood to get in the water any more than I absolutely have to.
I think a noise barrier is in order for this, at least until I can justify paying $$$$ for a quieter model. I'm having some trouble locating the blanket/wrap that CRB mentioned for sale, but I found this and I can get the materials fairly easy online so I think i'm going to try a variation on that approach http://www.soundproofing.org/infopages/generator.htm
So I found a decibel meter and spectrum analyzer app for my phone and did some investigation. The dB reading about where I was standing when taking the video was reading 77 (attached screenshot), however when moving around the pump itself at the areas I put yellow X's I was getting about 70-72 dB, but as soon as I put my phone to the spot where the red X is, it spikes to 80-82 every time!
Zolakk,
Here's a website for one of the manufacturer's of the blankets I was referring to.
http://www.tepinc.com/en/product-applications
I hope this helps!
Chris
Zolakk,
The readings you're indicating aren't bad at all. As I recall OSHA limit for needing hearing protection was 85 db. This was usually measured at 10' away and the rules may have changed since my days in the field on this stuff. At 85 db exposure for prolonged time (8 hour shift) we'd mark the area for required hearing protection (ear plugs). What's the measurement at a distance people normally would walk by at, say 5-10'?
Chris
That pump is too big for your pool. That said have you talked to the installer about a warranty claim?
I think your right about it being vane passing frequency, although if you do the math it looks more like six vanes:Is that a five vane impeller. Might be vane pass frequency.
What is the filter pressure?
If you can get a vacuum gauge on the suction side, then we can use both readings to determine where the pump is on its curve.
