I posted a few days ago about my Pentair IC40 dying and needing to balance water manually in the interim. I normally have a pool service, but they only come by monthly, so I needed to learn about water chemistry.
Starting last Saturday, I begun adding liquid bleach. I used a Taylor K-1004 test kit to test for chlorine -- every time I tested, I got 0.0. I noticed that the R-0002 reagent said "best by 2/23" so I figured it was expired.
Over the past 5 days, I have added 1 gallon of bleach per day. See attached photo of bottles used. I have used the Orenda app to determine my target chemicals to add. (side note, I also added 1/4 gallon of Muriatic Acid to get my pH down from 8.1).
I also dropped in a floating tab dispenser with two chlorine tabs last weekend. They are about halfway dissolved now.
Today my TF-100 Salt test kit arrived (shout out to TFTest Kits and their super fast shipping!). These are the numbers I got:
Temp - 89F
FC - 0.0
CC - 0.0
PH - 7.2
Alk - 70
CH - 225
CYA - 80
Salt - 3000
So everything else is good, except chlorine. Why have 5 gallons of liquid bleach over the past week not brought my FC up? Are they expired? I found date codes on some of the bottles. 22 188 (I assume 188th day of 2022?). 23 131. I've used Home Depot HDX 8.25%. And also Lowes Pool Essential 10%.
What am I doing wrong? Why can't I get chlorine in my pool??
Edit to add: Vinyl pool, 16,500 gallons. Pentair system.
Temp - 89F
FC - 0.0
CC - 0.0
PH - 7.2
Alk - 70
CH - 225
CYA - 80
Salt - 3000
