I wanted to provide some closure for anyone who might run into a similar problem in the future and as payback for all the kind folks who helped me in this thread.
Problem: I was having difficulty with the shock process because I could not determine my FC levels because during the FC portion of the FAS-DPD test my solution would flash 'clear' but then turn back to pink before I could start the CC test.
Solution: Based on advice from duraleigh (Dave), the FC test is done or almost done when the FC flashes clear. At most, you should add 2-3 more drops to see what happens but in most cases you can consider the FC test to be done and record your result for FC even if the solution turns to pink after a few seconds. Some testing instructions you might find say that the solution will return to pink if you wait for a minute or more. What I was seeing was a return to pink after less than 10 seconds.
What was happening? Well, it turns out I had an extreme but unknown ammonia problem. This was causing me to have extremely high CC readings (somewhere in the 20s ppm) because I wasn't adding chlorine quickly enough to break down the unexpected rise in CC. I was trying to perform the shock process by adding the pool calculator amount of chlorine. I would wait 1 hour then retest. However when I'd retest, the FC levels were actually way lower than I was expecting because I didn't realize that ammonia was consuming the chlorine almost immediately. So I'd add 10-12 ppm chlorine, only to test in an hour and find that my solution would flash clear after only 5-6 drops. In fact, the FC was combining with the ammonia in such a way that the CC number was skyrocketing, causing the difficulty in the FAS-DPD test by turning the solution back to pink without the need to add the R-0003 reagent for the CC test. I believe some folks refer to this as the CC 'bleeding through' on the FC test. I wasn't trusting my results because I didn't have enough experience with the test to know how to read the strange results.
Once I realized that the FC result should be recorded when the solution flashes clear, it became much easier to determine how much chlorine I needed to add. This, along with frequent testing and an ammonia test, made it obvious just how quickly and why my FC was being consumed. I've since been able to keep my CC down by maintaining a shock appropriate level of FC and my ammonia problem is almost gone.
So word to the wise for any newbies out there...if you are running a FAS-DPD test, and your solution flashes clear but just won't stay that way for more than a few seconds, you probably have an extremely high CC reading. Stop and record your FC right there. Oh, and you might want to go out and get an ammonia test.
