- May 26, 2011
- 47
- Vinyl
- Liquid Chlorine
We just opened our large 36,000 gallon pool. Pool opening test results were
FC 0
pH 7.2
Total Alkalinity 80
CYA 0
Pool temperature 70 F
I expected our CYA to be on the low side but not 0. It ran low all last summer and was 35 when we closed the pool in September. We have to drain the pool below the returns to close so CYA is lower when we open in the pool for the summer. We are added 3.5 kg of dry stabilizer using the using the sock method which per Pool Math will raise our CYA by 26 ppm. I subsequently read that likely if the CYA is under 20 it may show as 0. I am concerned now that if the CYA was perhaps at 15 or so then I may be adding too much dry stabilizer at once.
Last summer we had very good success with keeping the CYA close to 30 ppm .
In retrospect I feel that we should have likely added 2 kg dry stabilizer and then retested before adding more. I am wondering if I remove one of the socks (as the stabilizer has not yet dissolved) will it be salvageable? will I be able to add it back in later if needed? ; or will it turn into a brick when I remove the sock? do I just discard it? and, if so how?; is it safe to put in the garbage? If I can use it later is there a way I should store it? I feel I should add the dry stabilizer at a slower pace and retest. I can buy fresh dry stabilizer if we need to add more later.
I believe we also added too much liquid chlorine at 10.8 as we are getting bleaching when doing the DPD test Bleaching When Doing a DPD Test. Based on the pool opening results I posted how much liquid chlorine should I add to start with? We follow the SLAM method when opening the pool but in the past I have always had enough CYA to follow the Chlorine /CYA chart for slamming. I will try the test again tomorrow morning and hope that some of the chlorine will have dissipated.
The bottom of the pool had a layer of sand/dirt which has been vacuumed away; the water is a bit cloudy but not too bad. It does not look like we will have any algae issues.
I would appreciate your thoughts re removing one of the socks and re how much liquid chlorine to add when CYA is less than 20; as well as any other thoughts you may have re how to proceed form here. Thank you.
FC 0
pH 7.2
Total Alkalinity 80
CYA 0
