Keep going & Maintaining slam fc until
CC is 0.5 or lower;
You pass an Overnight Chlorine Loss Test
AND
The water is clear.
(Crystal Clear w/no algae dead or alive)
Also Be sure you’re doing all the things
*Check & scrub every nook & cranny where algae may hide (light niches, steps, drain covers, ladder handrails, skimmer throats/weirs, abandoned lines, autofill, overflow drains, etc.)
*If water can go there, algae can thrive there.
*Run slam level water through all water features & lines for at least a couple hours a day during the
SLAM Process.
*Brush & or vac daily (this breaks up biofilms that algae uses to protect itself from chlorine)
*Backwash/clean filter when pressure rises 25%over clean pressure.
You can try adding a little DE to your sand filter to help capture the finer particles but you need to be able to babysit it.
A clean pool filter will increase the efficiency of your pool! ... your filter are to backwash it, clean the manifolds and grids, and add new DE.
www.google.com
If you think your sand may be clumped up with magic potions
from the past you can do a deep clean of the sand - this is something that should be done every season or two anyway. It gives you a good opportunity to also verify that the sand level is correct.
I see you have a robot - if it has ultra fine filters or pleated filters be sure to use them & run the bot frequently along with your daily brushing.
