Moved from HERE
Do NOT? or Do? Or am I just misunderstanding what you said? Because you are supposed to attach the "elbows" and rails before the legs.Ok the instructions with Intex do not tell you to attach all of the elbows and rails before the legs. If you do that you can fit them in lifting the last one up a few inches and gently sliding them together. I just assembled a 14 ft round alone without problems. If the legs are on it is nearly impossible. Hope this helps.
