Hi all! New here and eager to learn!
I have a prism 15’x48 inch pool that I put up last year. I purchased a 2150gph intex sand filter (with the saltwater system) over the winter. The new pump uses 1.5” hoses.
I have no problem cutting the liner for the 1.5in fittings. I have a few questions for the experienced.
First off, is it recommended to replace the strainer (s) with the larger 1.5” ones? I am using the deluxe skimmer. So I’m not quite sure that the bigger strainer that the skimmer hooks to would make much of a difference.
Secondly; Alternatively, would it make more sense to leave the strainer connections as they currently are (1.25 connections) and use the t-plunger to connect the strainers to the new pump?
Third; has anyone moved their inlet to one of the strainer holes instead? Curious as the inlet hole is so high up, I’m curious if making one of the strainer holes the inlet and plugging off the existing inlet hole is a better option.
Thank you all in advance!
