Okay. I finally got my Intex sand filter setup after a sand nightmare.
One of the local pool stores sold me "Filter sand" or at least they said it was. It wasn't marked on the bag anywhere and i ended up taking their word for it.
So I basically ended up with ~10lbs of sand in the pool.
Basically my I am just concerned. I have the filter running and I have seen some videos of people with the 2100 and 2650 sand filters on their pools and you can see the flow very strong on the top of the pool. On my pool I don't see much flow on the surface even with the nozzle aimed up to the surface.
I am wondering if there is some reason my pump isn't pumping much or if its fine and I'm just paranoid.
Filter Pressure is half way in the green mark ~5psi. - Both plunger valves are open and locked and none of the inlets/outlets are clogged as far as i can tell.
