I have a puzzling one. I have an Intermatic T1004RT1 enclosure with a timer inside.
The switch will not turn to the ON position, not even manually.
I checked the breakers, they are fine and getting power. Even the timer I can hear the tick tick tick. The dial is moving and the time is correct. But it will not turn the pump on. I tried to throw the switch on manually, the switch will not move! It appears to be stuck. Any ideas?
