Hey guys,
Recently having a new issue with my pool timer not being able to turn the main off/on switch. The problem seems clear, but I am hoping someone has a better answer than mine, which is to replace the unit for $50+.
The yellow timer dial is working. You can not only see the gears in the back constantly turning, but it also keeps the correct time if you were to have no switches on it. The problem is when the timer dial runs into a on or off switch. I.E. When the pool pump is turned on, the timer dials gets all the way to the OFF switch and then stops. The timer dial seems to be having trouble pushing the Main Switch over. I have check the gears, and they are all greased up normally, and nothing looks wrong. Please take a look at the pics, you can see in the picture how close it is to flipping the main switch. This also happens when the pool pump is off and the timer dial runs into the off switch.
Any help is much appreciated!
