I am trying to figure out if the Easy Touch systems is adequate for me or if I should go IntelliTouch. From the other threads I have read it sound like the main difference is expansion and macros. I don't plan to connect any devices outside of normal pool equipment so the main difference for me is then macros.
Can the Easy Touch do multiple things without macros? For example, can a Spa button be programmed to turn the valve so the jets turn on, adjust the variable pump speed up, and turn on the heater? Or is this the type of function you need a macro for?
