Hi folks - long-time lurker/avid consumer of the tons of useful information on this site.
As the title says - primary equipment for our existing in-ground pool/spa is an Intellitouch 9+3 and an Intelliflo VF pump, all installed in 2006. I recently spent a couple long days rewiring the system to bring it up to current code: moved the feeder out of the IntelliTouch load center to a separate Siemens panel board so I could put GFCI breakers on every load.
100% certain everything was hooked up correctly; system ran normally yesterday, starting and stopping the pool at the scheduled times.
Today, however, while the IntelliTouch turned the pool on at the scheduled start time, the Intelliflo pump did not come on; turning the pool or spa on or off with the Intellitouch itself in service mode, or the wired (indoor and spa side) or wireless remotes turns everything else on and off, but the pump doesn't run.
Things I've tried/checked:
- Confirmed the pump has power (wired directly to a 20 amp 2-pole breaker on the panelboard, which has additional feeders to the Intellitouch pump relay to feed a separate Intellichlor. Pump has 240v all the time; Intellichlor has power only when the pool is turned on (IntelliTouch switching the relay correctly).
- Restarted both pump and controller several times and in different order (pump or controller first)
- Confirmed IntelliTouch is communicating with the pump - pump LCD shows "Keypad Inactive", Intelliflo Status on the Intellitouch remotes shows the pump at position 1, system normal but not running
- Disconnected the IntelliTouch control cable from the pump, was then able to control the pump manually via its LCD - starts, runs, and regulates flow correctly
- Tried removing everything else (spa side and indoor remotes, wireless remote, Intellichlor) from the IntelliTouch RS485 bus
- Deleted and re-added the pump configuration in the IntelliTouch
The IntelliTouch is controlling all the valves and relays correctly when switching from pool to spa and back and as cleaner and heater turn on, so I'm guessing it's not a board issue in the Intellitouch.
Unfortunately service call is a couple days out and hold times at Pentair tech support this afternoon were 4+ hours.... anybody got any thoughts?
Thanks in advance
Thanks in advance
