Hi all, I've tried all the settings and consulted the manual. I am obviously missing something or there is a bug- probably me.
Problem 1: If I manually turn on my hot tub it starts correctly 90% of the time. The other 10% of the time, the valves are not commanded to move to the spa positions and I wind up heating the pool through the spa waterfall. The valves work fine. It's a control problem. If I switch to filter, then back to spa, the valves move to the correct positions.
Problem 2: If I manually turn on my hot tub before a scheduled pool filter start time, then the filter schedule starts, the valves switch to pool filter mode and cold water it pumped into the spa for the spa waterfall.
I think the two problems are related. I have priority enabled. At least I think so.
What am I missing?
What am I missing?
