Hello,
I'm hoping someone can help. Last week I had to change the manifold on my Sta+Rite heater, when I doing so I inadvertently caught the low voltage wires underneath while bolting. I noticed it when I smelled an electrical burn. I immediately shut off the breakers. The smell was more pronounced at the Intellitouch control panel. I have spliced the wires and don't get an reaction when I touch the "heater" button on the panel.
Further, I have tested where the low voltage wires connect to the back of the board with a multi-meter, and while I do get a reaction when the button is hit the voltage doesn't change. I'm assuming I may have burnt on of the relays soldered to the smaller circuit board, but before replacing that expensive unit I wanted to see if anyone had experience with that type of short, and any other things to check.
Thanks for anything you can contribute.
Best,
Alex
Best,
Alex
