Pentair could create a system curve generator for their IntelliFlo VSF paired with IntelliCenter.
The pump could run a program where the pump runs at several different speeds and records the flow and head loss.
Then, with enough data points, a system curve is generated on the IntelliCenter web page.
The System curve can be displayed as a graph where you could input the pump speed and the pump performance curve would be graphed on the same graph as the system curve so that you could see the operating point.
You could input a desired flow and it would tell you the speed required, how much power would be used and the system pressure.
You could input a pump speed and it would show the flow rate, system pressure and power usage expected.
The system could be used to generate a system curve for different configurations such as solar on or solar off.
