- Aug 29, 2023
- 8
- Vinyl
- Pentair Intellichlor IC-40
Hello,
I have run into some strange behavior with my ET and pump that I haven't been able to solve.
I run 2 schedules, the second one is to ensure my heat pump doesn't turn on during the night (my electricity isn't time of use)
POOL - 45 GPM 12 hrs (VSF)
AUX 3 - 24 GPM 12 hrs (VSF)
The POOL schedule runs fine and the ET says "AUTO". Pump status I believe said normal. Pump display reads display not active.
The AUX schedule will not run, even though the ET will clearly light up and switch to AUX 3. The pump completely shuts off - no flow, no display. The pump light on the ET does NOT turn on and when I check the pump status on ET it says "NO COMM".
Both schedules ran fine until about 4 days ago and the evening one mysteriously stopped working.
I ran the ET self test and it failed with code "14".
I've already shut off the breaker, re-energized and reset multiple times to no avail. Any ideas?
Thank you
Thank you
