I have finally completed my first SLAM and pool looks great except for some tannin stains that lightened a bit during the slam. Now the issue is that I stopped bleach and turned on my ic20 swg at 100% at 8pm last night fc was 5 cc was 0.5. 7am today fc was 2.5 cc was .5, I put it in boost mode all day and 8pm fc is 1, cc hard to tell solution might have had the slightest pink to it for the cc test.
All other levels are within range. Cya is a little low at 55-60 depending on what recommendation I look at
Salt is a bit high at 4600
All lights on swg are green. This am just to be sure I cleaned the cekk with acid even though tell plates look clean and bright. Almost no bubbling from the acid so I assume the cell is clean check is 260 and take is 110 for what is worth, pH is 7.4
Any toughts? I have no idea how old the unit is as it came with the house.
Hanks
Bob
FYI the pump has been on 24/7 too
Hanks
Bob
