So I was reading the installation manual on the ETI 400 heater, and it states that you can install multiple heaters in parallel:
The question that I have is about control via the IntelliCenter. It doesn't look like the ETI 400 heater has an RS485 connection, so it would have to be the fireman's switch.
Assuming a single temperature sensor connected to the Intellicenter and heaters are hooked up in Parallel as outlined above heating a single body of water, and that for control the desired outcome is that both heaters turn on together until the setpoint is reached, is it "ok" to connect both heater fireman switch connections to the Gas Heater (J2) port?
Later on in the ETI 400 manual, it has this cryptic statement (highlighted), and I'm trying to understand what it means:
I'm assuming that one side of the fireman's switch has voltage, so polarity would matter in this sitution, otherwise the power from one heater may be completing the fireman's switch circuit for the other heater...
