- Aug 23, 2022
- 141
- Plaster
- Pentair Intellichlor IC-60
Hi, I tried searching around but couldn't find any information about this, but I have a hard time believing I'm the first one with this problem so I probably missed something.
I have a feature pump that runs a slide and a 10' wide sheer decent. I just put an actuator on the valve that controls the output to the slide and the waterfall in hopes that I could run the slide on its own without all the noise associated with the waterfall. It works great! Only issue is... The slide's pump speed is set to 1100 RPM and the sheer decent is set to 3200 RPM, so when switching from one to the other the pump ramps up much faster than the valve moves and for a brief moment the slide sprays water across the yard like a fire hose. What I'd like is to have a delay or a slower ramp time on the pump so that the slide doesn't shoot water across the yard every time we turn on the waterfall. I tried the 'Valve Delay' setting in the intellicenter, but it seems that's only related to Pool/Spa circuits and doesn't affect the valves A & B.
Hopefully this makes sense, but let me know if I can clarify at all.
