Hey guys my liner blew out on my 15x30 metal framed above ground pool, I caught it with the edge of my brush..
I have a sand bottom with sand coves but I'm taking out the sand cove and putting in ridged insulation and a foam cove instead.
Here are my questions,
1. The sand has some algea growing in it should I scrap it out and spray something down?
2. The walls sections go out in a circle a little bit do i cut the sheets with a little curve on them or just let the cove take care of that little gap?
3. Will 1" extruded pink rigid foam be thick enough?
4. Should I put a tarp on top of the foam and if so what kind?
Thank you for the help,
Brannon McCarthy
Brannon McCarthy
