My main battle with my pool for 20+ years is maintaining enough suction to keep my skimmer skimming and my Hayward crawler crawling. As the DE filter clogs and the back pressure rises this gets harder and harder. Not enough suction to go around.
This year installed new DE filter grids and was amazed at how good the flow was. Crawler was moving even when high speed (2800 rpm) switched to low speed (1500 rpm) and the water fall stayed strong as well instead of turning to a dribble.
After a Phoenix monsoon dropped a bunch of dirt and leaves in my pool a couple days ago I worked to clean it up, noticed the waterfall and suction was weak even at high speed, and so I did a first backwash. I did a 2 min backwash, water looked clean, then recirculated pool for ~15 min before another 30 sec backwash. Added 4-5lbs DE and while it now runs OK, it seems the vains are not transmitting nearly as well as when the grids were new...suction is back to marginal.
Would more backwash have helped? Another explanation?
