Hi New Dude, I am in the planning stage of adding a heat pump and a salt generator to my 16 X 36 In ground pool. I noticed what you said in an earlier post about mounting the cell vertically , and wanted to make sure I understood you correctly. You say the flow switch should be mounted “ before” the cell If you mount the cell vertically?That makes a lot of sense to me and never thought of that before.Do you have your cell mounted vertically or horizontally, and has it worked out for you?
Thanks , I appreciate your input.
Nbjoe43
Nbjoe43
